How to extract URLs from HTML and create features?
  • Mar 12, 2019 8:23 AM UTC
  • 10 replies
  • 487 views
Hi FME ninjas,
I'm using the HTTPCaller to call a website containing multiple URLs in its HTML.
I'm trying to extract all the URLs that have below format, based on these I'd like to create and attribute (URL) that shows all unique urls as features.
What I have:
What I want:
Does this make any sense ;-) ?
Thanks,
Eduard
Best answer by nielsgerrits
**Update**
With the addition of @takashi, something like this might be what you need.
htmlextractor2018.fmwt
**Original**
Looks like this question?
HtmlExtractor, a[href] as CSS Selector. Does this work in your situation? Did not try yet...
nielsgerrits
Forum|alt.badge.img+67
  • Mar 12, 2019 8:30 AM UTC
**Update**
**Original**
  • Mar 12, 2019 8:58 AM UTC
**Update**
**Original**
Yes, the HTMLExtractor does the trick. You can extract the URLs as a list attribute directly with this setting.
  • Mar 12, 2019 9:24 AM UTC
Mmm... I can't seem to get any data using above HTMLExtractors.
Can you perhaps have a look?
This is the page I'm trying to read: https://www.primera.nl/winkels/
My workbench so far:
Cheers,
Ed
  • Mar 12, 2019 9:28 AM UTC
Cheers,
Ed
Yes I can.
  • Mar 12, 2019 9:33 AM UTC
Yes I can.
Oh oh... I forgot to explode the list huh?
nielsgerrits
Learned something new today, thanks.
  • Mar 12, 2019 9:46 AM UTC
Thank you @nielsgerrits / @takashi for your quick responses.
I have exploded the URL list and I now have the data I was looking for.
Best,
Ed
jkr_wrk
Forum|alt.badge.img+37
  • Mar 12, 2019 10:06 AM UTC
With the following settings I get a list of 511 shops.
Indeed with a ListExploder. I always forget it is called that.
  • Mar 12, 2019 10:15 AM UTC
I currently have 493.
I will try your approach, thanks for sharing.
  • Mar 12, 2019 10:59 AM UTC
Cheers,
Ed
Some pattern matching are available in CSS selector expression. For example, this setting extracts only URLs which begin with "https". See here to learn more: CSS Selector Reference
a[href^="https"]
In addition, you can also download the source HTML directly with the HTMLExtractor.
