how to extract text between *** text *** from text file attribute
  • May 25, 2020 2:28 PM UTC
  • 146 views
I would like to extract text between *** CProtOC*** as a separate attribute from text file
* E * *** CProtOC *** FCLID [5318] - FCL [Fuse] - FOID [2634] - KEY_ID node NOT FOUND text_line
Forum|alt.badge.img+54
  • May 25, 2020 2:33 PM UTC
You can use the following regular expression in a string searcher which will return any text that is sandwiched between groups of 3 asterisksd
(?<=\*{3}).*(?=\*{3})
