I am trying to extract a PDF attachment from an ArcGIS Online feature layer and write it to another online program using the HTTPCaller. (I can do so with CSV attachments.) I can see the PDF is being read by FME Desktop (2020.1.2.1 - build 20624); it's in the arcgisonline_attachment{0}.data attribute but I'm not able to successfully write the PDF contents to the other program. Other forum posts indicate I should use the BinaryDecoder first but it won't decode using either option - Binary64 or HEX. I get an "Invalid Base64 character '%'" or "Invalid HEX character '%'" error. I tried using no decoder and writing the contents of the arcgisonline_attachment{0}.data attribute to the output location directly but get the following error: Received HTTP response header: 'HTTP/1.1 400 Bad Request: Invalid .pdf file.'. What do I need to get the contents of the PDF in the proper format so I can upload it?
