How to extract numbers and characters from a string?
  • Jul 14, 2016 1:48 PM UTC
  • 12 replies
  • 3058 views
I have an attribute that contains a string representing a full street address (123 Somewhere St). I want to extract the number (123) and pass it to a different attribute (CustomerAddressNumber). I also need to extract all the characters (Somewhere St) and pass that to another attribute (CustomerAddressStreet). I'm sure this is simple, I just cant seem to get it straight at the moment.
Best answer by erik_jan
Using regular expressions in the StringReplacer can do this for you. I would copy the original attribute in two new attributes and then remove the non wanted charachters with nothing.
For the numeric values this would be [0-9]*, for the alphanumeric [a-z,A-Z]*
I am sure other regular expressions are possible.
erik_jan
Forum|alt.badge.img+26
  • Jul 14, 2016 1:59 PM UTC
  • Jul 14, 2016 2:32 PM UTC
This works well. But it leads to one additional question. How would I remove a single space left at the beginning of the Street Name ( Somewhere St)? I tried adding |\\s to the expression ([0-9]*|\\s) and get this (SomewhereSt). It removes all spaces. I'm not real familiar with regular expressions.
  • Jul 14, 2016 2:42 PM UTC
Got it (^\\s|[0-9]*). Thanks for the help.
Forum|alt.badge.img+5
I'll also point you to this exercise in the FME Desktop training manual.
In short it takes an address like "3305 W 10th Av" and splits it up into "3305" "W 10th Av". It doesn't use regex, instead it uses an AttributeSplitter. It's not a perfect solution (it assumes a maximum of four elements to the address) but it's definitely along the lines of what you are asking for.
jdh
Forum|alt.badge.img+41
  • Jul 14, 2016 4:03 PM UTC
I would actually do it with a single StringSearcher with the expression:
^([0-9A-Z]*) ([0-9A-Z ]*)
(note the white space between the two parentheses)
The _match{0}.part would be the building number and the _match{1}.part would be the street.
An attributeRenamer could rename them to simple attributes. (Note that the AttributeManager does not currently support renaming single elements of a list)
That would allow for addresses like
350 5th Avenue or 221B Baker Street
  • Jul 15, 2016 11:59 AM UTC
CustAddress contains "123 Somewhere St". With the StringSearcher configured as shown the result in field "_first_match" is "123 Somewhere". How do I get _match{0} and _match{1}?
jdh
  • Jul 15, 2016 1:43 PM UTC
Click on the advanced tab and enter a name (_match) in the subexpression matches list name.
  • Jul 15, 2016 1:56 PM UTC
got it thanks.
gio
Forum|alt.badge.img+15
  • Jul 15, 2016 2:37 PM UTC
depends on the compostion of your adresseses
something like "strname number letter postalcode" would require
(.*)\\s+(\\d+\\w{1})\\s+(\\d{4}\\w{2})
Then expose the attributes, in my case that would be matched_part{0-3}
recommend searching sites on regexp.
There are full and good tutorials out on the net.
gio
  • Jul 15, 2016 2:39 PM UTC
check out the one by
Jan Goyvaerts. (regexbuddy)
(ued to be free, now not so..)
jdh
  • Jul 15, 2016 2:46 PM UTC
got it thanks.
Upon further reflection I would change the regex to
^([0-9A-Z]*) ([0-9A-Z -.]*)
ex.
124 Blvd. Saint-Germain
This issue is very old, but if you want one group of numbers in a simple variable, try [0-9]+ . The plus make difference in the result.
