How to extract medium value of XYZ in FME
  • May 18, 2023 3:54 AM UTC
  • 7 replies
  • 117 views
vimva679
Forum|alt.badge.img+11
I have got data as below
AssetID X Y Z
A. 0 0 1
B. 1 0 0
C. 0 1 0
D. 1 0 1
E. 4 5. 6
F. 9. 8. 7
G. 6. 9. 5
am able to extract
max of each row
min of each row
how to obtain medium of each row as simple as possible ?
am using
@max ( value of x , value of y, value z)
@min ( value of x , value of y, value z)
medium ?????( plz note it’s not average or median of 3 value ) It’s exactly absolutely value the same as it is in excel files.
Best answer by caracadrian
Test file
this is input data
this is my expectation
plz any help / support appreciated
Here you go:
caracadrian
Forum|alt.badge.img+23
  • May 18, 2023 10:02 AM UTC
You can put them in a list:
l{0}=@Value(X), l{1}=@Value(Y), l{2}=@Value(Z)
then you can either use the ListStatisticsCalculator custom transformer from the FME Hub or use a ListSorter followed by an AttributeManager that creates a new attribute with it's value equal to the sorted l{1}.
vimva679
  • May 19, 2023 1:28 PM UTC
@caracadrian​ hello Please am not really getting this right, please is it possible for you to create demo ?
vimva679
  • May 19, 2023 2:33 PM UTC
Test file
this is input data
caracadrian
  • May 21, 2023 8:14 AM UTC
Test file
this is input data
Here you go:
vimva679
  • May 22, 2023 3:45 PM UTC
Test file
this is input data
@caracadrian​ I didn't realize that the CELL value was a combination of numeric and alphanumeric.
Irrespective of its Alphanumeric character (ignore the alphabets), the Max, Min an Medium was that i am aiming for .
caracadrian
  • May 22, 2023 4:50 PM UTC
Test file
this is input data
A little StringReplacer and some conditional voodoo and you can easily achieve this.
I created copies for each attribute(AttributeCopier), eliminated the whitespace and letter part (StringReplacer- \\s?[a-zA-Z]?), got the statistics (ListStatisticsCalculator) and replaced the initial values back (AttributeManager).
vimva679
  • May 22, 2023 5:04 PM UTC
Test file
this is input data
Perfect , that works so well thank you
image @caracadrian​ , am so much grateful once again for your quick response as well.
