How to extract intersection lines from circles?
  • Oct 9, 2019 8:56 PM UTC
  • 82 views
dataninja
Hi everyone, I have a geometry question.
As you can you in the following image, I have three different circles that overlap. How do I extract the red lines?
erik_jan
Forum|alt.badge.img+26
  • Oct 9, 2019 9:31 PM UTC
I have created a workflow that creates (almost) the required output:
The output looks like this:
Hope this helps.
Here is the FME workspace (FME 2019) : Roads_from_circles.fmw
fmelizard
Forum|alt.badge.img+22
  • Oct 9, 2019 9:44 PM UTC
not_arcs_b19642.fmw Hi @trungn1993 This method uses a VoronoiDiagrammer, Chopper (to 2-point lines), and a NeighborFinder searching a distance slightly less than that specified in the VoronoiDiagrammer.
dataninja
  • Oct 9, 2019 9:55 PM UTC
Hope this helps.
it's really close :) but not good enough unfortunately
Forum|alt.badge.img+54
  • Oct 10, 2019 7:30 AM UTC
I'd coerce to lines, then use a line on line overlayer followed by a test to keep the overlapping lines only
voronoi_intersection_lines.fmw
