How to extract data from multiple excel docs with varying formatting using FeatureReader
  • February 4, 2025
  • 66 views
ecx
Hello,
I have 4 excel documents hosted on SharePoint, I am using a FeatureReader taking in a temp download path.
As can be seen the 4 items are being opened successfully in the featurereader, but the data is not grouped in any meaningful way for me to extract and sort out the various excel documents data (which is varying formatting, some have multiple tabs with differing data/headers between them, as you can see there are 14 schemas (total tabs within excel docs), and 1546 generic bits of data (total rows))
I’ve read that I can re-group the datasets by using fme_basename but I cannot work out how to expose this, I’ve found the post below, which offers suggestions of how to expose that data. But the solution it offers is not applicable, I am using version
Does anyone know how I can expose the fme_basename?
OR
Is there a better way to do this?
Best answer by ecx
I’ve found a solution to exposing the fme_basename.
tools->edit headers, add: “READER_META_ATTRIBUTES fme_feature_type fme_dataset fme_basename” without quotes.
see link below
Also this link might be useful for anyone else who finds this question, and how to sort the items out afterwards:
ecx
  • February 5, 2025
see link below
ecx
  • February 5, 2025
2nd link: https://community.safe.com/transformers%2D9/how%2Dto%2Dread%2Dattribute%2Dnames%2Dfrom%2Dmultiple%2Dexcel%2Dworkbooks%2Dsheets%2Dto%2Dnew%2Dworkbook%2D27011 wasnt that useful, instead to finish off my workflow I used fme_feature_type (exposed using instructions above) combined with attribute exposer to expose the items I needed.
