How to extract a "grandchild" feature using the JSON Fragmenter?
  • Mar 9, 2021 9:56 AM UTC
  • 310 views
dangeerah
Hello, I am trying to extract a set of attributes that appear to be "grandchild" away from the parent feature. I am using the JSONFragmenter, and can extract from the parent using the JSON query: json["data"][*], but within this are four child attributes including "geometry", "properties" and "id".
I really want to split out a number of attributes within the "properties" section but don't know what I should put in the JSON query? Some of the desired attributes within properties are "laFeatureType", "reference" and "fieldName". But putting json["data"][*]["properties"]["reference"] in the query builder doesnt work.
Any help would be greatly appreciated 😀Screenshot 2021-03-09 at 09.49.53Screenshot 2021-03-09 at 09.49.04
danilo_fme
Forum|alt.badge.img+58
  • Mar 9, 2021 10:31 AM UTC
Hi @dangeerah​
Please, could you share the json file?
Thanks in Advance,
Danilo
nielsgerrits
Forum|alt.badge.img+67
A good trick to get the correct json query, is to save the response body to a file, temporarily change input source to file, select the saved file and use the tree to select the element you want, which gives the correct query. Then change back to attribute.
JsonQuerySelect
dangeerah
  • Mar 9, 2021 12:49 PM UTC
Hi @dangeerah​
Thanks in Advance,
Danilo
Hello @danilo_fme​ ,
I have emailed you a single feature JSON file with the "properties" attribute.
Any help would be appreciated, Thanks 😁
dangeerah
  • Mar 9, 2021 12:53 PM UTC
JsonQuerySelect
Thanks for this. I have tried this and put it in the data query, but would it be along one line like:
json["data"][*]
json["data"][*]["properties"]["area"]
json["data"][*]["properties"]["laFeatureType"]
Then attributes to expose:
properties
area
laFeatureType
But this does not return any values?
Thanks
