How to expose dynamically created attributes not known in advance
  • Jun 4, 2024 3:13 PM UTC
  • 508 views
aaron
Forum|alt.badge.img+12
I am creating some attributes dynamically, which are then present but unexposed. I will not know the names of these attributes in advance. How do I expose them so I can do some downstream processing with the attribute values? I can’t use the AttributeExposer since I don’t know the attribute names in advance.
  • Jun 4, 2024 4:11 PM UTC
aaron
  • Jun 4, 2024 8:22 PM UTC
I need to expose the dynamically created, unexposed attributes before I write out the final results so I can process the data contained in them. Maybe I’m missing something but it seems this only allows me to write out data using the dynamically created attributes.
