How to expose a large amount of attributes created inside a PythonCaller?
  • Jul 18, 2019 12:31 AM UTC
  • 160 views
I have a process inside a PythonCaller that converts a long pandas dataframe into a wide dataframe that when output, has around 200 columns. The dataframes are transformed back into an fme feature for output. Now I need to expose all 200 column names but need to avoid doing this manually. Is there any way to do this from within the PythonCaller?
Best answer by david_r
If you could write a CSV file (e.g. from your Python script) with all the attribute names, then you can import this list into the AttributeExposer.
  • Jul 18, 2019 7:09 AM UTC
  • Jul 19, 2019 12:45 AM UTC
Thank you @david_r
