How to export data from text file
  • Aug 1, 2023 11:00 AM UTC
  • 147 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
i have read text file but I see only one column in FME
Important data starting from fifth column
fifth row include the name of each column
| col1 |col2|col3|col4| col5|
rest of columns include data like this
|..0383004|Abcd…………|383903…..|Dhaka Gheny 2|………|
I see in one column all data ,as what I explained above .
i would like to get the data into excel file .
i would like to export the name or number between | | so I need to have five columns and each column include the data that belongs to this column as text file
thanks in advance
FME 2021
Forum|alt.badge.img+63
If you read it with the CSV reader, use the | as separator character and specify which line to start reading and which has the column names you should be able to then write it to Excel.
gogopotter90
  • Aug 1, 2023 11:49 AM UTC
thanks for ur reply
but I have put at delimiter character |
data start line 5
but I see the output is null at the column
but I keep it auto in delimiter character ,i got many columns
two Data inserted in one column
|number|string| some not at different cells .
could u provide small workspace to use it correctly .
i believe ,csv reader the reader that I need to use .
thanks for help
thanks for ur reply
data start line 5
thanks for help
imageThis is what I'm getting. Since the line starts with a | FME inserts an empty column col0 but you can safely ignore that.
You say: data start line 5, but in your first post you said the column names are on line 5, maybe that's it.
