How to eliminate empty spaces in address field?
  • Feb 18, 2023 1:02 AM UTC
  • 59 views
vxn43
Forum|alt.badge.img+20
If I have addresses in an address field formatted for example:
1234 Elm St
...and I want to remove all spaces to change the field value to look like this:
1234ElmSt
What Transformer and Parameter would I use?
Best answer by danilo_fme
Hi @timh​
There is another sugestion for your case. Is the custom transformer StringCleaner:
StringCleaner
Thanks in Advance,
Danilo
tomfriedl
Forum|alt.badge.img+14
  • Feb 18, 2023 8:58 AM UTC
You can use StringReplacer​. Substitude space through nothing.
danilo_fme
Forum|alt.badge.img+58
  • Feb 20, 2023 11:16 PM UTC
Hi @timh​
StringCleaner
Thanks in Advance,
Danilo
