How to dynamically create a table from json metadata?
  • Aug 29, 2019 2:03 PM UTC
  • 10 replies
  • 514 views
aguan
Forum|alt.badge.img+11
I have multiple json files, each containing a database table schema definitions. For example, the extraction of one json file, breaks down to column names and data types (non-spatial), as shown in the attached Data Inspector image. How can I use this information to dynamically create a table in the database ?(Oracle).
  • Aug 29, 2019 2:36 PM UTC
Hi @ag, I think you can build SQL statements from the JSON documents and execute them to create DB tables with the SQLExecutor transformer. If you could share a few samples of the JSON files, I would try implementing a workspace example.
itay
Forum|alt.badge.img+19
  • Aug 29, 2019 2:37 PM UTC
Hi @ag,
I would look into creating a schema feature (list) from the JSON attributes and using that in the writer, see the following link for more info.
Hope this helps,
Itay
itay
  • Aug 29, 2019 4:00 PM UTC
Hi @ag,
Hope this helps,
Itay
Here is an example creating some data (name and fme_data_type) and necessary schema attributes (fme_geometry{0} and fme_feature_type) and dynamically writing.
aguan
  • Aug 29, 2019 8:23 PM UTC
Hi @ag,
Hope this helps,
Itay
@itay, interesting. I saw a similar example somewhere, but did not work for me. What the writer settings look like?
aguan
  • Aug 29, 2019 8:35 PM UTC
@takashi, curious how you do that dynamically. I am attaching one example of the json file.
basin_header.json
  • Aug 29, 2019 10:20 PM UTC
Please find the attached workspace example which demonstrates how you can convert the JSON document to a SQL statement (CREATE TABLE).
json_to_sql.zip (FME 2019.1.1)
itay
  • Aug 30, 2019 5:46 AM UTC
Hi @ag, the writer is set according to the same way as described in the link provided. Basically using the dynamic mode with fme_feature_type as table name.
See section 4 https://knowledge.safe.com/articles/1051/index.html
itay
  • Aug 30, 2019 10:38 AM UTC
Hi @ag,
Here is an example workspace with your data (FME 2019.1.0.0). json2dynamic.fmw
aguan
  • Aug 30, 2019 1:44 PM UTC
Thanks for the URL. I need to change the column_name to be exactly "name" and use "attribute" as the list. it works now. I have an issue with one column though. The "entitled_key" is varchar2(65536), so fme_varchar(65536). The FME gives and error on "create table ..." sql. This sql is mis-formed at the end in FME. The reason is that the standard length limit for Oracle 12c on varchar2 is 4000. After I change the column_size to be 4000, it successfully creates the table . Many thanks.
aguan
  • Aug 30, 2019 2:20 PM UTC
@takshi. I am on FME 2018.1, can not get your Aggregator open. But I can see what you are doing. I did not know the same attribute can be repreated in the same AttributeCreator. This is useful when I want to appliy the primary key and null able constraints. Would like to try this when I find a json that has these constraints. Many thanks.
