How to draw extern contour of dwg plan
  • Mar 22, 2019 1:55 PM UTC
  • 7 replies
  • 63 views
Hello,i would like to calculate the surface of a dwg plan. My first approach was to make a bounding box and calculate the area but it's not precise enough.
I was wondering how i could do something like that :
The blue line is at 4 meters of the feature ....
I hope you see what I mean , and hope that you could help me.
Thanks a lot.
Best regards.
Steph.
Forum|alt.badge.img+54
  • Mar 22, 2019 1:59 PM UTC
You could buffer the feature by 4m and then calculate the area of the polygon created
I thought to that possibility but the thing is my drawing is made of thousands lines and I want that the most outside lines define the "polygon area"...
as you see in my drawing (sorry I'm not autocad drawer) the black lines are my features and I want to get a polygon just as the area inside de red lines
  • Mar 22, 2019 2:50 PM UTC
Ok, if your data is like that then a hull accumulator might be a better possibility. You could still use the bufferer but you would need to dissolve afterwards. Or you could aggregate then buffer.
Thanks for this info.
I didn't know this transformer.
It's a bit more what I want to achieve....
If i could reach the red line area, it would be perfect !
  • Mar 25, 2019 7:53 AM UTC
Did you try the aggregator followed by a bufferer?
itay
Forum|alt.badge.img+19
  • Mar 25, 2019 12:55 PM UTC
Hi @stephanemarly,
It think the buffer approach might work if you aggregate your features into one feature using the aggregator transformer and then buffer it and calculate the area.
Hopes this helps,
Itay
gabriel_hirsch
Forum|alt.badge.img+16
If you first aggregate your features with the Aggregator and then use the HullAccumulator transformer you might end up with a result that is useful for this purpose.
