How to download and save multiple DTM zip files from CSV with URLs. Need help with settings for extracting individual files
  • December 1, 2023
  • 8 replies
  • 93 views
gattogis
Best answer by takashi
Thanks. I did the same thought. In my case the csv already contains a FILENAME column, but I’m not able to set this FILENAME in the Output Filename field.
"C:\Users\Francesco\Desktop\dtm austria" is a folder path, is not a User Parameter. You don't need to quote it by $( ).
Try setting this string to the Output Filename parameter.
C:\Users\Francesco\Desktop\dtm austria\@Value(FILENAME)
See here to learn more aboud User Parameters.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/published_private_parameters.htm
  • December 1, 2023
Hi @gattogis​ ,
I think you can read URLs from the CSV file with CSV reader, extract filename part from each URL with FielnamePartExtractor, and download the DTM zip file with HTTPCaller into a specific folder.
HTTPCaller parameters setting looks like this. Assuming that "url" stores a URL read from CSV, "DONWLOD_FOLDER" is a user parameter spacifies a folder path to which you would like to downlaod the DTM zip files, and "_filename" stores a zip filename extracted from URL with FilenamePartExtractor.
httpcaller-paramers-example
gattogis
  • December 1, 2023
Hi @gattogis​ ,
  • December 2, 2023
Could you please share a few rows of the CSV table?
gattogis
  • December 2, 2023
This is a simplified version of my csv with only 2 rows, for my tests
  • December 2, 2023
I was able to download the files from urls described in the CSV table.
However, it took very long time. ​Possibly you may have to set a large value to the Transfer Timeout Length parameter of the HTTPCaller.
csv-reader-httpcaller
gattogis
  • December 2, 2023
I still receive translation FAILED message as:
2023-12-02 21:47:43|      |     |INFORM|Starting translation...
2023-12-02 21:47:44|      |     |INFORM|Undefined macro `C:\Users\Francesco\Desktop\dtm austria' dereferenced in file `C:\Users\Francesco\Documents\FME\Workspaces\wb-xlate-1701550060797_22284'
2023-12-02 21:47:44|      |     |INFORM|Program Terminating
2023-12-02 21:47:44|      |     |INFORM|Translation FAILED.
I have the workspace shown below:
Screenshot 2023-12-02 214707
  • December 2, 2023
gattogis
  • December 2, 2023
Thanks! That worked fine. Now i understand where the problem was.
