How to directly edit the parameters of the attribute manager (again)
  • Dec 13, 2022 8:42 AM UTC
  • 7 replies
  • 152 views
mferber
since my last update of the workbench (2022.2.0.0 (20221103 - Build 22765 - WIN64)) the parameter editor of the attribute manager wont allow me anymore to edit directly in the pane next to my main window. I have to open a unneccessary pop-up window to continue editing. Other transformers (like the feature joiner) do not show this behavior (see screenshot). Any ideas how to enable direct editing again?
All the best,
Merlin
Forum|alt.badge.img+63
Try View -> Windows -> Parameter Editor (though it should either work for all transformers, or none, not for "just a few")
mferber
  • Dec 13, 2022 1:08 PM UTC
as you wrote ... it just turns the window pane on or off ... dosent solve my attribute manager problem ...
egge
Forum|alt.badge.img+14
  • Dec 13, 2022 1:20 PM UTC
Hi Merlin,
I can confirm your findings. I have tested the AttributeManager in FME Workbench in the version you mentioned (2022.2.0.0 (20221103 - Build 22765 - WIN64)) and no, it is not possible to edit the parameters of this transformer in the Parameter Editor window... Weird.
Maybe this has something to do with a 'fix' mentioned in the Change Log:
FME 2022.2.0.0 b22743 20220928
[Fix] AttributeManager: Opening, editing, and closing the transformer with the Parameter Editor window open causes the workspace to freeze
 It looks like the option to edit the parameters of this transformer in the Parameter Window has (temporarily?) been disabled to avoid the whole thing to freeze. Safe Software?
HTH,
Egge-Jan
evieatsafe
Forum|alt.badge.img+28
  • Dec 13, 2022 11:55 PM UTC
Hi Merlin,
HTH,
Egge-Jan
Thanks for bringing this to our attention, and yes this is something we have been looking into. Looks like this has been fixed for build numbers b23147 and b22745 and future versions. (internal ticket FMEDESKTOP-13258) Please try using these new versions. Let us know if you come across any other issues.
Happy to help, Evie
mferber
  • Dec 14, 2022 1:14 PM UTC
Happy to help, Evie
Hi Evie,
i am running now 2022.2.1.0 (20221202 - Build 22776) and the problem persists.
dustin
Forum|alt.badge.img+36
  • Dec 14, 2022 1:49 PM UTC
Happy to help, Evie
I'm seeing the same results as @mferber​ in build 23194.image
evieatsafe
  • Dec 14, 2022 11:41 PM UTC
Happy to help, Evie
I would have thought this would be supported on both of those versions! Sorry for the inconvenience. I have brought this to the attention of the developers and will report back. Thanks for your patients.
