How to cut overlap polygons in order of their attribute value
  • Jul 31, 2018 6:04 AM UTC
  • 8 replies
  • 81 views
Please help
and aattributes
pratap
Forum|alt.badge.img+12
  • Jul 31, 2018 6:18 AM UTC
cutp1.png is not uploaded properly
  • Jul 31, 2018 6:44 AM UTC
I have ESRI shape files with overlap polygons. And i need cut them by order Speedlimit attribute
pratap
  • Jul 31, 2018 7:05 AM UTC
Does that mean you want to cut polygons based on speed attribute?
  • Jul 31, 2018 7:09 AM UTC
It is important that it should be in order. first cut from the least
SliverRemover ? or ?
pratap
  • Jul 31, 2018 7:40 AM UTC
If you want to cut based on SppedLimit attribute then you can use Clipper with group-by option
  • Jul 31, 2018 7:49 AM UTC
untitled.png I need same result
Forum|alt.badge.img+54
  • Jul 31, 2018 7:56 AM UTC
For this scenario I would use an area on area overlayer, then determine the lowest speed for each segment and use this to dissolve the segments back together again.
Simple example attached
speedlimits.fmwt
  • Jul 31, 2018 12:13 PM UTC
