How to create geometries with a python caller?
  • March 14, 2019
  • 321 views
arthy
Forum|alt.badge.img+8
Hello,
How can I replace a line with its corresponding points with a python caller?
I tried the following code but it is not working.
import fme
import fmeobjects
class pointCreate(object):
    def __init__(self):
        pass
    def input(self,feature):
        if feature.hasGeometry():
            coord = feature.getAllCoordinates()
            cpt = len(coord)
            #coordSys = feature.getCoordSys()
            for cpt in range(0,len(coord)):
                feature.setAttribute('X_e', coord[cpt][0])
                feature.setAttribute('Y_e', coord[cpt][1])
                feature.setGeometry(fmeobjects.FMEPoint([float(coord[cpt][0]), float(coord[cpt][1])]))
                #feature.setCoordSys(coordSys)
                self.pyoutput(feature)
    def close(self):
        pass
Any ideas,
Thanks
Best answer by ebygomm
Easier to step through the coordinates like this, but as @david_r said, the chopper followed by a coordinate extractor will do the same thing and would be my preference.
            coords = feature.getAllCoordinates()
            for coord in coords:
                feature.setAttribute('X_e',coord[0])
                feature.setAttribute('Y_e',coord[1])
                feature.setGeometry(fmeobjects.FMEPoint(coord[0], coord[1]))
  • March 14, 2019
Why use a PythonCaller when you can use a Chopper set to 1?
If you also need the X/Y as attributes you can follow up with a CoordinateExtractor.
  • March 15, 2019
The constructor of fmeobject.FMEPoint class requires two or three individual float values representing coordinates. See the API reference if you want to leverage Python FME Objects API.
http://docs.safe.com/fme/html/fmepython/api/fmeobjects/geometry/_points/fmeobjects.FMEPoint.html#fmeobjects.FMEPoint
I think this code could work for you.
                feature.setGeometry(fmeobjects.FMEPoint(coord[cpt][0], coord[cpt][1]))
Forum|alt.badge.img+46
  • March 15, 2019
  • March 15, 2019
Personally I prefer importGeometryFromOGCWKT for creating anything in FME python so therefore create a string as Well Known Text format and pass that in.
feature.importGeometryFromOGCWKT("POINT({0} {1})".format(*coord))
This is really good for creating lines and polygons
https://en.wikipedia.org/wiki/Well-known_text_representation_of_geometry
