How to create geometries with a python caller?
  • Mar 14, 2019 2:10 PM UTC
  • 421 views
arthy
Forum|alt.badge.img+8
Hello,
How can I replace a line with its corresponding points with a python caller?
I tried the following code but it is not working.
import fme
import fmeobjects
class pointCreate(object):
    def __init__(self):
        pass
    def input(self,feature):
        if feature.hasGeometry():
            coord = feature.getAllCoordinates()
            cpt = len(coord)
            #coordSys = feature.getCoordSys()
            for cpt in range(0,len(coord)):
                feature.setAttribute('X_e', coord[cpt][0])
                feature.setAttribute('Y_e', coord[cpt][1])
                feature.setGeometry(fmeobjects.FMEPoint([float(coord[cpt][0]), float(coord[cpt][1])]))
                #feature.setCoordSys(coordSys)
                self.pyoutput(feature)
    def close(self):
        pass
Any ideas,
Thanks
Best answer by ebygomm
Easier to step through the coordinates like this, but as @david_r said, the chopper followed by a coordinate extractor will do the same thing and would be my preference.
            coords = feature.getAllCoordinates()
            for coord in coords:
                feature.setAttribute('X_e',coord[0])
                feature.setAttribute('Y_e',coord[1])
                feature.setGeometry(fmeobjects.FMEPoint(coord[0], coord[1]))
  • Mar 14, 2019 2:16 PM UTC
Why use a PythonCaller when you can use a Chopper set to 1?
If you also need the X/Y as attributes you can follow up with a CoordinateExtractor.
  • Mar 15, 2019 5:10 AM UTC
The constructor of fmeobject.FMEPoint class requires two or three individual float values representing coordinates. See the API reference if you want to leverage Python FME Objects API.
http://docs.safe.com/fme/html/fmepython/api/fmeobjects/geometry/_points/fmeobjects.FMEPoint.html#fmeobjects.FMEPoint
I think this code could work for you.
                feature.setGeometry(fmeobjects.FMEPoint(coord[cpt][0], coord[cpt][1]))
Forum|alt.badge.img+54
  • Mar 15, 2019 8:31 AM UTC
  • Mar 15, 2019 11:39 AM UTC
Personally I prefer importGeometryFromOGCWKT for creating anything in FME python so therefore create a string as Well Known Text format and pass that in.
feature.importGeometryFromOGCWKT("POINT({0} {1})".format(*coord))
This is really good for creating lines and polygons
https://en.wikipedia.org/wiki/Well-known_text_representation_of_geometry
