How to create File folders from excel column
  • Jan 14, 2025 8:17 AM UTC
  • 5 replies
  • 144 views
tamadur
I have Excel sheet with 2 fields, and I need to create folders with the values of the field
tomfriedl
Forum|alt.badge.img+14
  • Jan 14, 2025 8:34 AM UTC
You can use the SystemCaller to start Windows-Cmd:
Command:
cmd /k "md c:\temp\test2 & exit"
Forum|alt.badge.img+63
Do you just want to create folders, or also write data to them?
tamadur
  • Jan 14, 2025 9:31 AM UTC
Command:
thanks i will try
tamadur
  • Jan 14, 2025 9:32 AM UTC
yes, just empty files by names of values attribute
tomfriedl
  • Jan 14, 2025 10:39 AM UTC
You can write Textfile’s. With the params
Write Last Line Terminator = no
Write UTF Byte Order Mark = no
will create files with 0 Byte. Missing folder create the writer automatically folder.
