How to create a Polyline shapefile from CSV/excel data
kburande
Best answer by redgeographics
Ok, you can use 2 VertexCreators, one to create a point at the start easting/northing and a second one to add a point at the end easting/northing. That'll give you a 2-point line for every record in your Excel file. Potentially you can use a LineCombiner to join them into longer lines, but it looks like there's gaps between them.
Forum|alt.badge.img+49
That really depends on how the data is stored in your source file, can you share an example?
kburande
In my csv I have start and end easting(X) and northing(Y) also the lengths of pipes see the highlighted fields below
kburande
kburande
Thanks a lot , that was very helpful!!😀
