How to create a good nested structure (geometry gml with xml templater)
  • Nov 18, 2017 6:37 PM UTC
  • 69 views
Very hard question to post here :
I work on a project to write AIXM5.1 AirspaceTimeSlice. In the writer, i have a field [xml_geometry ] : Surface.
Inside this field i can found <gml: geometricLineString> nested structure, <gml:arcbycenter> nested structure in different positions. ( Not known when i read the feature ).
When i read the feature in FME, i'm able to recognize an arc and put in an XML templater the definition of this geometry in gml fields.
But i don't succeed to write the <geometricLineString > définition.
It shall contain <posList > éléments of each point defining the IFME Line. e.g :
<posList> Long(A) Lat(A) Long(B) Lat(B).....Long(k) Lat(k) </posList>
I have the points in a list :
Long {0} A
Lat {0} A
I don't succeed in writing after the whole structure Surface by combining the different parts ( the order is random )
Best answer by takashi
Assume the lists Long{}.A and Lat{}.A contain the coordinates to be listed within the "posList" element, this is a possible expression to generate the required element.
<posList>{
let $lat := fme:get-list-attribute("Lat{}.A")
for $x at $i in fme:get-list-attribute("Long{}.A")
return ($x, $lat[$i])
}</posList>
  • Nov 18, 2017 10:04 PM UTC
<posList>{
}</posList>
