How to create a field that contains the minimum measure value of a polyline
  • Apr 24, 2019 6:35 PM UTC
  • 89 views
The polyline is already measure aware. The field would be called "Begin Measure"
I would also want another field that contains the maximum measure called "End Measure"
Thanks
Best answer by ebygomm
You can use a MeasureExtractor - choose type 'individual vertex by index'
0 index for the start and then a second measure extractor with -1 for the end
Alternatively you can choose whole line which will give you all measures as a list, and then use a listindexer to get the first and last values
Forum|alt.badge.img+54
  • Apr 24, 2019 6:39 PM UTC
  • Apr 24, 2019 6:49 PM UTC
That worked!
Thank you egomm!
