How to create 256 color raster, where black color is exact on 0 index palette position, and white on 255?
  • March 4, 2016
  • 8 replies
  • 133 views
arekpierchala
I want to create rasters from vector data. I've used ImageRasterizer and set background color into white, then write data as geotif with 8BiitsPerCell parameter. Finally got 24bit raster with 16,7milions colors but I need 256 color raster with black color on 0 index palette position, and white(background) on 255.
Best answer by geosander
@arekpierchala
You have to set the Interleaving Type on the Format Parameters tab (on the GeoTIFF writer) to BIP. That will do the trick.
According to the docs, palettes in FME are "Band Interleaved by Pixel" (BIP).
  • March 4, 2016
Hi @arekpierchala, the RasterPaletteGenerator transformer might help you.
geosander
Forum|alt.badge.img+7
  • March 4, 2016
True! Set the interpretation type of the ImageRasterizer to RGB24 and leave the interpretation type of the RasterPaletteGenerator on UInt8. Set to "Number of Palette Entries" to 256 of course.
arekpierchala
  • March 4, 2016
Hi @takashi and @sander_s
Still something is wrong. When write into TIFF, FME create file with orignal colors =256, but current colors pallete is still in fact 16,7 millions
  • March 4, 2016
I'm not sure what the "Current colors" in the screenshot means. Can you inspect the actual data structure of the tiff raster with FME Data Inspector?
geosander
  • March 4, 2016
It's an IrfanView screendump ;)
geosander
  • March 4, 2016
@arekpierchala
arekpierchala
  • March 4, 2016
parcels-good.zip
256colorrasterizer.fmwt
please look at the template, DataInspector shows 256 pallete, but when I open the image e.g. in IrfanView the pallete is in fact in millions. Need raster as attached 'parcels-good.tif' - IrfanView shows for that file current and original colors = 256
mark2atsafe
Forum|alt.badge.img+59
  • March 4, 2016
@arekpierchala
Good find. It would have taken me a while to think of that!
