How to COUNT total number of NULL values for EACH records ?
  • Jun 16, 2023 3:28 PM UTC
  • 200 views
vimva679
Forum|alt.badge.img+11
As an eg. there are 4 records i wanted to check how many null values are present for each records .
Best answer by ctredinnick
Use an attribute exploder to split every attribute into a name/value pair. Then a Tester, to test that attr_name is the attributes you care about, and attr_value is null. Then Aggregator with Group By your ID, the number of features in the aggregation will be the count of null attributes.
ctredinnick
Forum|alt.badge.img+22
  • Jun 17, 2023 10:17 AM UTC
