How to count the amount of times a value is present
  • Feb 14, 2014 6:13 AM UTC
  • 485 views
Hi there,
What I have is a dataset with a field named UPDATE. in this field, there are many differant values populated. Here's an example (imagine each line is an entry in the dataset table):
UPDATE
DESCRIP ; E_MAIL ; TEL_NR ; WEBSITE
E_MAIL ; WEBSITE
DESCRIP ; WEBSITE
DESCRIP
DESCRIP ; TEL_NR
etc.. Please not that these multiple values (like DESCRUP ; E_MAIL) are contained in a single attribute.
So what I want as a result is to calculate how many times a set of specified values are present:
UPDATE                         COUNT
DESCRIP                      4
E_MAIL                          3
TEL_NR                        3
WEBSITE                      4
Currently my writer is an xls table, but I've had very little luck in achieving this output.
Any kind of help would be fantastic.
fmelizard
Forum|alt.badge.img+22
  • Feb 14, 2014 7:26 AM UTC
One way to do that would be to:
  1. Split the UPDATE attribute > AttributeSplitter set on ;
  2. Clean list elements > StringReplacer text to find: ;|" ", replacement text " ",  use regular expressions: yes
  3. Explode list > ListExploder
  4. Aggregate > Aggregator group by _list , set a count attribute (_count)
There are probably other ways.
gio
Forum|alt.badge.img+15
  • Feb 14, 2014 11:51 AM UTC
Staying fully in listtransformers u can
remove spaces->split on ";"->eplode list->build list grouped by  "_list" (assuming you didnt rename default)->listelementcounter on "_list"-> remove list.
Now u have atribute and its count.
Thanks guys, I just tried both methods, and they work beatifully!
