How to copy FME format attributes
  • Nov 7, 2018 3:08 PM UTC
  • 66 views
I am using FME Workbench 2018.1.0.1 in Windows 10. I am inputting a kmz file. The only parameter I am reading from it is PLACEMARK because I see no reason to read the others. I need to copy format attributes kml_name and kml_description to NAME and CAPACITY, respectively. I don't see in the AttributeCopier transformer where I can do this. Its Import Wizard does not seem to be made to do this
Forum|alt.badge.img+54
  • Nov 7, 2018 3:19 PM UTC
If you have exposed the format attributes you can just use an attribute creator to create your new NAME and CAPACITY attributes and choose the kml_name and kml_description for the value
mark2atsafe
Forum|alt.badge.img+59
If you haven't exposed the attributes yet, then do it like this:
