How to convert zmap grid to ESRI grid?
  • Jul 22, 2019 1:53 PM UTC
  • 378 views
aguan
Forum|alt.badge.img+11
We need to batch convert map zmap grid files (ascii) to ESRI Grid (ascii). FME has zmap grid reader which successfully read my zmap grid file. But just directly connecting ESRI Grid writer to the reader does not work. Does anybody have an example workspace to do this conversion?
itsmatt
Forum|alt.badge.img+48
  • Jul 22, 2019 5:17 PM UTC
Is there an ERROR in your log file? Perhaps you could share it? Does the FME Data Inspector show the original data looking ok when you try and view it?
aguan
  • Jul 22, 2019 9:14 PM UTC
@virtualcitymatt , if I just connect the zmap reader and the ESRI Grid writer, the error message is "
Esri ASCII Grid Plugin: Opening the Esri Ascii Grid writer for file '\\\\americas.ent.bhpbilliton.net\\pfs\\Asset\\GOM\\06 Exploration\\GOM_Central\\03_Geology\\Petroleum_Systems\\Basin_Modelling\\CRS_CCRS_zmap_123-20190718\\MM96\\ESRI_ASCII_GRID'
ESRIASCIIGRID writer: Failed to obtain raster from feature. Only features with raster geometry are expected".
I can view the original zmap file in the data inspector.
itsmatt
  • Jul 22, 2019 9:47 PM UTC
Ah ok - in that case it seems like the writer is getting data which is not raster/image data. It seems the zmap reader can read both vector and raster data. To check the geometry types you can look in the data inspector of pass the data through a geometry filter. The writer only supports rasters so it might be failing because either there are no raster data or there are some other data types causing issues.
Use a geometry filter to just direct your raster data to the writer.
If you find you have no raster data, then check the reader parameters - there might be a setting you can change.
As a last option if you only have vector data check out some of the articles here on the knowledge base about converting vector to raster like this one: https://knowledge.safe.com/articles/1099/converting-vector-data-to-raster.html
aguan
  • Jul 23, 2019 8:58 PM UTC
Yes, I used the geometry filter to filter out the raster and the conversion is successful. Thanks a lot for your help. @virtualcitymatt
