Best Answer
How to convert string to date format in FME?
  • January 5, 2023
  • 1596 views
smfks911
Happy New Year all.
Can anyone please how can I change a date column (dd/mm/yyyy) from string to date time format within a workbench. The column is originally coming from a CSV file but after reading in FME, its getting converted into string. I want to apply test filter to get values within a certain date period but because the date is in string, I cannot do it. Do you have any idea how to resolve the issue? Thanks in advance.
Best answer by geomancer
Take a look at the DateTimeConverter.
DateTimeConverter
geomancer
Forum|alt.badge.img+60
  • January 5, 2023
DateTimeConverter
Forum|alt.badge.img+46
  • January 5, 2023
You can also parse the string to a date within an AttributeCreator/AttributeManager
@DateTimeParse(@Value(date),%d/%m/%Y)
smfks911
  • January 5, 2023
DateTimeConverter
Thank you @geomancer​ . I later avoided the problem by converting CSV to Excel from the source. And in ExcelReader, the field does not change interestingly.
smfks911
  • January 5, 2023
Thank you @ebygomm​ :)
