How to convert NAS files (German AAA) to FeatureClass (ESRI) ?
  • Sep 26, 2018 2:18 PM UTC
  • 86 views
I want to convert some NAS files to FeatureClass (ESRI)
. Do you have any idea, how to di it?
Thanks and best regards
Sajjad
you can download examples of this files from: https://www.opengeodata.nrw.de/produkte/geobasis/lika/alkis_sek/bda_oe/
oscard
Forum|alt.badge.img+23
  • Sep 27, 2018 1:31 PM UTC
Do you have any particular issue with the workflow?
I see they are XML files, so you can read them with the XML Reader. You will have to configure it depending on the fields you want for your FeaureClass, The Writer would be ESRI FIleGeodatabase or ArcSDE Writer.
I've seen that some of the XML are pretty large. No idea if FME has any kind of limitation for XML size.
