How to convert multiple dgn file to multiple shapefile by FME?
  • Jul 18, 2021 4:11 AM UTC
  • 135 views
khaphan
Hello everybody,
My project need to convert amount dgn files (more than 2000 files) to shapefile and I want the output also are multiple shapefile which equal dgn files. I'm a newbie in FME, so who know the exactly way to convert multiple dgn files let's support me. Thanks for everyone!Capture
caracadrian
Forum|alt.badge.img+23
  • Jul 18, 2021 8:04 AM UTC
The first thing to consider is that shape files are geometry dependent. Points go to a points shape file, line to a line shape, etc. DGN in not.
For that many files I would use Directory and File Pathnames reader with a Path Filter set to *.dgn followed by (a Tester first with path_filename CONTAINS -V8 followed by) FeatureReader configured as Bentley Microstation V-what_version_the_files_are, Dataset set to path_windows attribute and Attribute Accumulation set to Merge Initiator and Result.
Send that to a GeometryFilter for Point, Line, Area, Text, Whatever_else_you_need.
Each output goes to a shape writer set as follows: Shape Name = @Value(path_rootname)-{[geometry_type]}. (You fill in the geometry_type by hand, point, line, etc)
That mostly covers the translation. You may have some trouble with the schema and you may have to configure it as Dynamic if you want to bring other attributes from the DGN files.
Have a go at it and if you have any problems just come back to the community.
khaphan
  • Jul 18, 2021 8:07 AM UTC
Thank for your support! I just want convert line feature of dgn to shapefile. I try with FME but the output file which merge 2000 files to 1 file.
kailinatsafe
Forum|alt.badge.img+24
Have you considered using a fanout expression in your SHP writer?
khaphan
  • Jul 20, 2021 3:27 PM UTC
No, I have not yet tried this function! I' m reading the guide which your link. Thank you so much!Fanout Dataset
