How to convert Mapinfo TAB file, which contains annotation, to a SQL Server spatial table with point geometry
  • June 5, 2025
  • 15 views
sandanuwan
Dear All,
We need to convert TAB files that contain annotations similar to the following into a SQL Server spatial table with point geometry and an attribute to represent the annotation
I have created the following workbench but it does not update the “dimention” attribute with the annotation text available in the MapInfo TAB file
Output
emma.at.safe
Forum|alt.badge.img+8
Hi ​@sandanuwan,
Would you be able to send over the TAB files so I can take a look?
Also which version and build of FME are you using? You can find this information under Help > About FME Workbench.
Thanks!
Emma
