How to convert geotiff to CSV file or autocad file
  • Jun 11, 2020 2:34 PM UTC
  • 189 views
I have a geotiff in tif format & ovr format. I want to convert this to another format such as a CSV or autocad format but I can't seem to get the correct output. Any help is appreciated
  • Jun 12, 2020 6:50 AM UTC
For the CSV, you could e.g. use the RasterCellCoercer (output as points) followed by a CoordinateExtractor to retrieve all the raster cell values as numeric values.
If that doesn't cover your use case, maybe consider adding some details to the question.
I couldn't do it. I am new to FME, can you please break down the steps?
