How to CONVERT EXCEL data to ???? (preferably IFC 2x3)
  • Oct 25, 2023 9:25 AM UTC
  • 6 replies
  • 209 views
vimva679
Forum|alt.badge.img+11
image to
What is most important is i would like to add permanent different symbol for each 'GType' whenever i load it into Trimble Connect + AR Viewer
Forum|alt.badge.img+63
You can specify on the Excel Reader (in the properties when you're creating the reader) that certain columns should be treated as x, y and z coordinates. You'll also need to specify the coordinate system.
vimva679
  • Oct 25, 2023 9:39 AM UTC
How to add symbols to each elements eg. PLAT look like Square , PENE look like Circle , DOOR look like rectangle etc. ?
  • Oct 25, 2023 11:16 AM UTC
vimva679
  • Oct 25, 2023 1:49 PM UTC
@david_r​ and @Hans van der Maarel​ and @daveatsafe​ Not getting it quite right, i have used the article and recreated the workbench but it does not export IFC at the end only attributes are exported. For reference i have attached WORK and Data template (i have distorted XYZ and would not match or create any object, but if u wish to try you could INPUT XYZ values) . I am also missing step to give shapes to Gtype objects like square, rectangle, triangle, think line etc. for each Gtype. thank you with your previous input as well.
vimva679
  • Oct 30, 2023 1:05 PM UTC
imageWhen running till AttributeCreator, i could see all the points, when writing to IFC it looses all and nothing is get write out :( . Any idea . Highly obliged with help .
vimva679
  • Oct 30, 2023 1:07 PM UTC
attached is the most updated Workbench
