how to convert a sql table with Lat/Long to Feature class in SQL Server?
  • Jan 15, 2020 6:38 PM UTC
  • 205 views
judy_fme
I am new to FME. I think this is a simple quetion for you guys. I have a SQL table with two fields Longitude and Latitude and other attributes in SQL Server database. I need to it to Feature class into same database. how to do that? how to setup Longitude and Latitude fields as geometry fields in the reader?
Best answer by erik_jan
The transformer you will need after the reader is the VertexCreator.
This converts attributes to point geometry.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Jan 15, 2020 6:41 PM UTC
Hope this helps.
judy_fme
  • Jan 15, 2020 6:55 PM UTC
Thanks! I I am about to try. Appreciate!
judy_fme
  • Jan 15, 2020 7:21 PM UTC
Hope this helps.
I tried, it works! Thanks you so much! it is a great help! Appreciate! : )
