how to convert 3D Multipatch to DGN as cell
I have a multipatch Geodatabase or multipatch shapefile and I need to convert as DGN. The DGN output always are lines and I need to have the output a cell for every feature. Thus, when I click on the DGN feature I want to select the entire object and not only multiple lines as I am getting the output now.
Does anyone know how to solve this issue?
Jairo Castillo
fmelizard
Forum|alt.badge.img+22
Hi @jaircasti thanks for asking. At this point I don't think there is a way to write out geometries as a cell in DGN without the cell first being defined in the cell library (users please correct me if I'm wrong). There is an idea here which you can vote on to have this functionality added. Someone might have a workaround for this problem though.
daveatsafe
Forum|alt.badge.img+24
Hi @jaircasti,
FME's Microstation writer is currently quite limited in its surface writing. If you are opening the output file in Microstation, I would recommend writing instead with FME's AutoCAD RealDWG writer. This has much better support for 3D surfaces and solids, and DWG files can be opened and edited natively in Microstation.
Thanks Dave, it is exactly what I need. I transformed from gdb to AutoCAD RealDWG and I opened in MicroStation and every building is a cell. In addition to this, I opened the AutoCAD RealDWG in Microstation and I saved as DGN V8 and it worked, but I think keeping as AutoCAD RealDWG is working for what I need.
Thanks Dave for your help.
