How to construct lines from one dataset of points and one dataset of pairs
  • Mar 3, 2019 11:13 PM UTC
  • 103 views
nicholas
Forum|alt.badge.img+14
I have two tables.
One is a dataset of points, each point has a unique ID
The other is a (attribute only) dataset of pairs, each record refers to two points, via their unique ID
How do I construct a feature dataset of lines? Each line consisting of two points.
To re-phrase, how do I add line geometry to the dataset of pairs, using the appropriate points from the point dataset, based on the unique ID of the from and to points?
danilo_fme
Forum|alt.badge.img+58
  • Mar 3, 2019 11:53 PM UTC
Hi @nicholas
I suggest you to use the transformer FeatureMerger - to find the relation between the two datasets by ID.
After the use the transformer LineBuilder.
Thanks,
Danilo
  • Mar 4, 2019 2:00 AM UTC
A possibly way I can think of is:
  1. Merge the first point geometry to the features containing pair of IDs, with a FeatureMerger (Join On: ID of the first point, Feature Merge Type: Geometry).
  2. Extract coordinates (x, y) from the original point geometries with the CoordinateExtractor (Mode: Specify Coordinate, Coordinate Index: 0), and merge the (x, y) to the features output from the Merged port of the first FeatureMerger, with another FeatureMerger (Join On: ID of the second point, Feature Merge Type: Attributes Only).
  3. Use the VertexCreator (Mode: Add Point) to add the second point to the features output from the Merged port of the second FeatureMerger.
nicholas
  • Mar 4, 2019 2:05 AM UTC
I have done exactly that.
It works, but it seems not elegant.
I was hoping that there was a way to merge the geometries directly without converting the points from geometry to coordinate values and back to geometry again.
@nicholas I think I would go with @takashi 's approach - it would be much clearer for others to understand the workflow - even if it does require extracting the coordinates. However, there is an obscure part of the FeatureMerger functionality that can build geometries: Geometry Merge Type: Build Lines From Points. I've never used this before so thought this might be an excuse to try that. Here is the result:
Here's the workspace (2018.1): createlinesfromnodes.fmwt
