How to connectFME to a TIBCO EMS JMS queue
I am trying to build an integration between a few of our vendors, and one of them requires us to connect to a Tibco JMS queue. I'm not a java guy, and have been trying to find some information to help get this going, but has anyone set up this connection before that could help me?
Thanks!
erik_jan
Forum|alt.badge.img+20
  • July 15, 2020
I have no experience with JMS queues, but know that two transformers exist for connecting to JMS queues:
JMSReceiver and JMSSender
These links are for the documentation of the two transformers.
Hope this helps.
  • July 15, 2020
Hope this helps.
Thanks for the reply. I've seen those pages, but unfortunately I'm looking for specific settings/classnames/bindings needed to get the connect to work :)
  • August 13, 2020
Hope this helps.
We have gotten the jar files from the vendor installed in the plugin directory, and they seem to be found, but the error we receive is shown in this screenshot (along with the settings we're trying)
  • August 13, 2020
Hope this helps.
JMSError
steveatsafe
Forum|alt.badge.img+12
  • August 13, 2020
Hi @shester​ @mconway​
I believe we will need to look at this more closely at Safe Software Support. Sean, I'll reach out to you shortly. Hopefully we can post a solution back here soon.
Hi
Did you arrive at a suitable solution for connecting FME to EMS Queue - is this possible within FME?
steveatsafe
  • October 20, 2020
Hi @mark.buttle​ ,
We were able to get FME to connect to EMS Queue, however not with SSL enabled. So if that is not a requirement it is possible. If you need the SSL enabled it might be worth investigating that with you and if you could, submit a case at www.safe.com/support. Please address SteveAtSafe.
steveatsafe
  • October 20, 2020
steveatsafe wrote:
Hi @mark.buttle​ ,
And thanks for pinging this post. I can add an update.
  • October 22, 2020
We worked with the team at Safe, but were never able to get the Tibco JMS connection working on our side (our vendor required SSL). We had to settle for a java application that just forwards events from Tibco to an FME topic.
