how to compare two schema to see if there are duplicate fields?
  • Nov 12, 2019 7:23 PM UTC
  • 73 views
lobsterboy
As stated in the title,
I want to compare two schemas to see if they have duplicate field names.
My idea is to use the Change Detector, but i do not know how to expose field names from an reader
Any thoughts?
Best answer by david_r
You can use the "Schema (any format)" reader to get a list of all the fields in each schema. You can then use the ListExploder on the list before sending it to the ChangeDetector.
  • Nov 13, 2019 7:39 AM UTC
