How To compare two Date fields in a record, that too in fme 13
  • January 8, 2018
  • 142 views
  • January 8, 2018
Hi @vioarx, if the date values are formatted with FME standard date format (%Y%m%d), you can compare them as numeric values using comparison operators such as <, <=, etc.
  • January 9, 2018
I tried it, but when comparing in such a way the result is not convincing. I have checked for greater value and it gives result for both greater value and equal value.
gio
Forum|alt.badge.img+15
  • January 9, 2018
I mostly prefer to use tcl clock, format etc. to do date calculations.
Not very hard to learn even.
Gives great control.
  • January 10, 2018
Do you mean, for example, "20171201 < 20180131" and "20171201 = 20180131" both pass the test?
Could you please post some example pairs of two dates to be compared?
