How to compare two database schema (File GDB & SDE) including subtype & domains values.
  • June 23, 2022
  • 414 views
@hakkeem85​ You can compare the basic schemas using the FeatureReader - one for the File GDB and another for the SDE and check the <Schema> port. This will have a list attribute (attribute{}) with the schema of all the feature types.
For subtypes and domains, you'll have to export the Esri XML Workspace Document (Schema only) and then you can use a workspace to read that and interpret the XML. There is an example here
  • July 6, 2022
Thank you @Mark Stoakes​ it's worked. I have used Feature reader to compare feature class, field name & field type. Used python creator & SQL executer to get domain values ..
