How to compare the height of acogopoint with the height of the surface on the same x-y coordinate?
  • Mar 17, 2020 11:02 AM UTC
  • 101 views
sprongandre
I used the surfacedraper to drape the cogopoints on a surface, i'ts look like he doesn't do anything.
My goal is to compare the height of the cogopoint with the height of the surface on the same x-y coordinate.
My thought was to drape the cogopoint on the surface and compare the height.
civil3d2none.fmw
basic.dwg
Best answer by palhermans
Hi, my apologies @sprongandre. You do need to "extract" the coordinates of the draped point. Tested with CoodinateExtractor which gives the 1.23 (in a list of coordinates).
palhermans
Forum|alt.badge.img+11
  • Mar 17, 2020 11:47 AM UTC
I think the problem you are facing is due to the Surface Tolerance parameter. Set it to 0 and You will get a draped height of 2.56
sprongandre
  • Mar 17, 2020 12:41 PM UTC
Hi @palhermans, the cogopoint has the elevation of 2.56, the heigt of the surface is 1.23. So the cogopoint has to get a height of 1.23.
palhermans
  • Mar 17, 2020 1:53 PM UTC
sprongandre
Hi @palhermans, yessss that was the solution, thanks a lot! :-)
