How to classify the skp model based on their Name or layer name?
  • Jan 17, 2013 10:18 AM UTC
  • 68 views
i have a skp file, contains four model,as shown blow
i have give each of them a name, and set to different layer,as shown below
i want to classify them based on their name or sketchuo_layer_name
anyone knows how to do that?
thanks  for the help...
davideagle
Forum|alt.badge.img+21
  • Jan 17, 2013 10:36 AM UTC
In FME Workbench consider using an AttributeExposer to expose the required attribute like the 'sketchup_layer_name', then add an AttributeValueMapper and enter your possible values and the Classification you want them to map to. For example:
Source Attribute = sketchup_layer_name
New Attribute Name = _classifcation
ValueMappings:-
Layer0=High
Layer1=High
Layer2=Medium
Layer3=Low
Layer4=Low
Layer5=Low
Layer6=Low
Alternatively if your classifcations are more complex consider looking into the SchemaMapper.
  • Jan 17, 2013 1:41 PM UTC
Dave, thanks very much.
i'm not familiar with the function you mentioned
i do my best to make the work flow
and it still don't work well,
can you tell me what's wrong with my workflow ?
does't the parameters right?
blow is the link of my data:http://pan.baidu.com/share/link?shareid=240310&uk=722271433
i just want to transfor it from skp to gdb/multipatch
base on the name, it should have two record, base on the layer name,it also two, but i only get one.
  • Jan 18, 2013 12:43 AM UTC
Zao!   I assume you are trying to transform one aggregate feature containing different two geometry types - named "Box" and "Circle" - into two aggregate features grouped by the type name. If so, just a combination of Deaggregator and Aggregator might be helpful.   Reader (skp) --> Deaggregator Mode: Flatten One Level Geometry Name Attribute: _geometry_name --> Aggregator Group by: _geometry_name --> Writer (gdb multipatch)   Deaggregator saves the type name of deaggregated part as "_geometry_name", so you can group the parts by this attribute value.
