How to build a XQuery for extracting values from XML
  • May 23, 2023 10:39 AM UTC
  • 185 views
juanmahere
Forum|alt.badge.img+15
I think the best FME Transfomer for such type of extractions is the "XMLXQueryExtractor", but I do not know how to build the query.
The XML is contained within an attribute and could be something like this:
"<?xml version="1.0" encoding="UTF-16"?><value xmlns="http://spec.tn-its.eu/schemas/"> <gml:measure uom="kph" xmlns:gml="http://www.opengis.net/gml/3.2">50</gml:measure> </value>"
For that particular case, I wanted to extract that "50" value from that XML.
Thanks!
Forum|alt.badge.img+54
  • May 23, 2023 11:50 AM UTC
So something like this should work, where XML Input is Attribute specifying XML
declare namespace gml='http://www.opengis.net/gml/3.2';
//gml:measure/text()
Unfortunately, my knowledge of xml and xquery is fairly limited so I can't really explain how or why you'd arrive at this answer!
