How to build a path between points in JSON
  • Jun 17, 2019 9:19 AM UTC
  • 8 replies
  • 156 views
Hello!
I have a problem with creation a path between points, which are saved in JSON file. I tried a extract JSON file with using a JSONExtractor, and when I got coordinates of my points - but not in the form of a list.
Next to this, I use a StringReplacer Transformer to get a list of coordinates. And the result looks like this:
But when I try a read it to Path or LineBuilder, I don't have any result.
Below, I uploaded a part of my Workbench, where I try to build a path.
If anyone knows the solution of my problem, I will be grateful for any help or tips.
Greetings,
Karolina
Best answer by david_r
The following worked for me:
Result based on the sample feature you posted:
  • Jun 17, 2019 9:32 AM UTC
Is this some flavor of GeoJSON, by chance? If so, you can simplify your life significantly by simple passing the entire geometry string to the GeometryReplacer set to "GeoJSON" or "Esri JSON", depending.
  • Jun 17, 2019 9:43 AM UTC
Thanks David for your answer.
I tried GeometryReplacer set to "GeoJSON" but my output is Rejected. When I tried "Esri JSON", result is better (is not rejected, but I don't see any difference between Output and original JSON)
  • Jun 17, 2019 9:51 AM UTC
And probably my oryginal file is not GeoJSON. I download it from other service (which is created in our company) with using a HTTPCaller. I asked a Leader of Project about a type of JSON file and he told me, that this is probably JSON file, not GeoJSON.
  • Jun 17, 2019 9:55 AM UTC
If you could post a complete JSON feature here, as text, that would be helpful.
  • Jun 17, 2019 10:51 AM UTC
result.txt
Sorry for in this form, but I had a problem with adding a comment with long contents JSON file.
  • Jun 17, 2019 10:52 AM UTC
But when I download, upload JSON file with using HTTPCaller, it looks like that:
  • Jun 17, 2019 10:54 AM UTC
  • Jun 17, 2019 11:01 AM UTC
Thanks a lot @david_r. It is my expected result :)
