How to avoid gaps when applying DEM values to points
  • Jul 18, 2023 9:39 PM UTC
  • 115 views
johnk
I have a process where I am using a DEM to apply values to vertices of polylines using vertexextractor, point on rasterextractor etc (see below). But I end up with gaps where the z value has been attributed as -32767. These have occurred where the vertices are just outside of the clipped DEM - is there anything i can do to interpolate?Z value application exampleDEM gapsZ value error
hkingsbury
Forum|alt.badge.img+73
  • Jul 20, 2023 8:20 PM UTC
I wonder if you could use a rasterconvolver with the setup something like this to extend the edge of the DEM a bit...image
Another approach could be to resample the dem to a larger cell size (enough so "data" covers your lines) then resample it back down to your orignal cell size and use that output to fill in the 'Gaps'
danminneyatsaf
Forum|alt.badge.img+13
You could also try sending the raster back through a RasterDEMGenerator set to Planar mode to try and resolve this. According to our documentation, the planar mode will output the z value as NaN (Not a Number) for points that fall outside the 2D convex hull of the surface model. So values outside of that clipped DEM should essentially be NaN values.
