How to avoid AttributeExploder to add unwanted 'values'
  • Aug 9, 2021 4:38 AM UTC
  • 106 views
I'm using the AttributeExploder to prepare a two line table for an HTML report, the header as 'name' column and the value line has another.
How to avoid unwanted 'values' or hide them?
It adds those two:
fme_geometry fme_undefined
fme_type fme_no_geom
Or is there a way to filter out value before using in the HTML report transformer?
Best answer by itsmatt
If you can't find a solution that makes the result clean you can just use a tester after the AttributeExploder that tests if the names are like 'fme_%' (without the quote marks), that should catch all of these.
philipwhitten
Forum|alt.badge.img+15
Have you got the "Keep Geometry" parameter set to "No" for the AttributeExploder?
itsmatt
Forum|alt.badge.img+48
  • Aug 9, 2021 6:40 AM UTC
  • Aug 9, 2021 6:57 AM UTC
I do
  • Aug 9, 2021 7:10 AM UTC
Thank you! that's a great trick!
If that can help someone in the future:filter fme_
