how to automatically filter each value using AttributeFilter or another transformer?
  • Sep 14, 2021 10:24 AM UTC
  • 5 replies
  • 197 views
davidlee
Forum|alt.badge.img+9
FME 2016 Build 16494
I want to automatically filter each info field value and the workspace will run them one by one.
It's like:
Screenshot 2021-09-14 172459Then
Screenshot 2021-09-14 172547and
Screenshot 2021-09-14 172617Anybody help me ! pls ....
Best answer by caracadrian
Use Workspace Runner.
Create a workspace that will be ran depending on the value of a PARAMETER that the Runner workspace sends via attribute to the WorkspaceRunner.
Use Tester instead of AttributeFIlter with Right Value set to that parameter.
You can use StatisticsCalculator to get a single feature from the dataset in the Runner workspace (or Sampler with GroupBy set). OR, if your dataset allows it, use a WHERE clause in the reader (on the to run side) set to PARAMETER.
Runner_to_runOn the left the Runner and on the right the workspace to Run. Notice that the Test is done on the same attribute.
caracadrian
Forum|alt.badge.img+23
  • Sep 14, 2021 10:58 AM UTC
davidlee
  • Sep 14, 2021 12:25 PM UTC
i understand, but i'm using FME 2016 build 16494, it doesn't have the same features as the 2021 version
Screenshot 2021-09-14 192042Screenshot 2021-09-14 192326Do you have any solution on FME 2016 ?
caracadrian
  • Sep 14, 2021 12:31 PM UTC
In the workspace to be ran create a User Parameter that will be used to pass the attribute value through WorkspaceRunner.PARAMETERSSave the workspace, delete WorkspaceRunner reinsert it and you will have the option to set the value to an attribute
davidlee
  • Sep 14, 2021 3:25 PM UTC
I have done it, many thanks bro ! 😁
davidlee
  • Sep 25, 2021 6:13 PM UTC
Do you have any other solution without using WorkspaceRunner, by the way ?
