How to assign a dxf elevation values from a shapefile attribute field?
  • May 18, 2018 9:31 AM UTC
  • 40 views
I have a pointcloud in LAS format which I want to use as the basis for a CAD project.
I need to create contours in DXF format containing z-values from the pointcloud so that they can be imported into a CAD program and visualised in a 3D model.
What would be a good workflow to do this?
  • May 18, 2018 1:51 PM UTC
Hi @robertdbuckley, you can use the ContourGenerator to generate contour lines (3D line features) directly from a point cloud feature.
