How to append attribute name to an attribute value?
Is there a way to prefix/concatenate the attribute name and a separator character to all of the values on that feature? For example, I have a feature with 60 attributes - can I retain the values of each cell, but have the attribute name appended to the values without having to manually create each attribute.
Input:
AttributeName
abc
def
hij
Output
AttributeName
AttributeName|abc
AttributeName|def
AttributeName|hij
  • November 15, 2017
Have you looked at the BulkAttributeRenamer?
  • November 15, 2017
Or maybe I'm misunderstanding -- maybe "AttributeName" isn't a constant, but rather the actual name of the attribute? Example from:
a1=aa
b1=bb
To
a1|aa
b1|bb
Is that it?
  • November 15, 2017
Apologies @david_r for not being clear. For each of the 60 columns, I would like to append the name of the attribute to every value under that attribute.
dustin
Forum|alt.badge.img+31
  • November 15, 2017
I would use the AttributeExploder to get _attr_name and _attr_value attributes on the feature, and then a StringConcatenator to get the final result of _attr_name|_attr_value.
  • November 15, 2017
That's a good way of doing it for limited datasets. Just be aware that the AttributeExploder creates a separate feature for every attribute of every feature, so if you have 10'000 features with 60 attributes each, FME has to create 600'000 features and it will be slow.
  • November 15, 2017
In addition to the solution proposed by @cartoscro, here's one in Python that should have a more linear performance for larger datasets:
import fmeobjects
SEPARATOR = '|'
def processFeature(feature):
    for attr in feature.getAllAttributeNames():
        if not attr.startswith('fme_'):
            value = feature.getAttribute(attr)
            feature.setAttribute(attr, '%s%s%s' % (attr, SEPARATOR, value))
Also notice the mechanism for leaving the fme_* attributes untouched.
dustin
  • November 15, 2017
Good point, @david_r
  • November 15, 2017
This was my initial attempt, but my dataset is 30million features so I was trying to avoid exploding something that size on my laptop. Thanks though!
  • November 15, 2017
import fmeobjects
SEPARATOR = '|'
This looks like the best option given my dataset dimensions, I will give it a go. Thanks!
  • November 15, 2017
You're welcome. I'd be cool to know how it works out, seeing how much data you've got.
  • November 21, 2017
@david_r Sorry for the delay in response. This works like a charm and the data is flowing smoothly! Thanks for the advice and the code!
  • November 21, 2017
No worries. Glad to hear it helped you out.
